3 members (Jon G, Otto Skorzeny, 1955 1 Series), 85 guests, and 2 robots.
Topics128,026
Posts1,055,399
Members48,422
#891837 10/24/2012 8:12 PM
I have a heater/defroster that is mounted inside the cab, not under the hood. How do you disassemble the blower motor from the squirrel cage?
Thom Masterson
Bats62Chevy #892198 10/26/2012 7:43 AM
Do you have pictures? If it is like the ones mounted to the firewall, I believe you might need to cut out a few rivets.
~ HB
1962 Chevrolet C10
1962 Suburban
Hambone #892233 10/26/2012 10:38 AM
I do not have pics. I have the heater box and blower motor totally disassembled...free and clear of the firewall. It's all sitting on my garage floor.
The blower motor turns the squirrel cage which forces air through the heater box into the cab. The blower motor is attached to the squirrel cage but I don't know how to seperate the two. Any ideas?
Thom Masterson
Bats62Chevy #892235 10/26/2012 10:45 AM
the blower cage prolly needs to come off to access screws/nuts behind it - look for some type of press nut on the end of the shaft or a set screw that has to be accessed by weaseling between the cage fins
Flxible #892240 10/26/2012 10:56 AM
The end of the shaft looks like a capitol D. Is that a press nut? If so, does it take a special tool to loosen?
Thom Masterson
Bats62Chevy #892241 10/26/2012 11:06 AM
On mine the screws that hold the motor housing together extend through the fan shroud and then the 2 nuts and the fan are installed.
Give me ambiguity
or give me something else
Bats62Chevy #892256 10/26/2012 1:05 PM
Crusing in the Passing Lane
On the end of the shaft there should be a spring clip, be very careful not to break the clip, they aren't available. Some of the squirrel cages had a set screw inside on the shaft, you will need an allen wrench for those. Chances are the cage is will be stuck to the shaft, so a brass punch will drive the shaft out.
Currently cruising
in the Passing Lane
Rest in Peace
63burban #892285 10/26/2012 3:48 PM
thanks...any advice on how to remove the spring clip?
Thom Masterson
