Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
8 members (Stovebolt48, SNOYL, Hugh63c10, Cletus1950, Barnfind49, Gib70, Otto Skorzeny, klhansen), 76 guests, and 5 robots.
Topics128,281
Posts1,058,460
Members48,490
#892151 10/25/2012 11:47 PM
Y
Y Offline
I was wondering if anyone has dropped a 350 crate engine into a big bolt. I have a 1951 gmc 350 2 ton. I need it to be a work truck and was thinking of buying a new crate engine. If anyone has done this and has advice I would be appreciative. Is there an adapter for the transmission? Is this possible or crazy? etc. Thanks in advance.
Crusing in the Passing Lane
If it's going to be a work truck and carry loads and possible trailers, a better option than the 420 would be a 5 speed trans., i.e. NP-540, Clark, etc., don't necessarily need OD for a V-8, just determine avg. loads, see what gear ratio you have now, tire size-you could go w/ modern 22.5's rather than 20's, 19.5's look too small. Perhaps 4.11 or 4.56 ratios, depending on use, use what you have first, then select different if necessary.
Above and other trans'(465) come w/ GM bolt pattern, however, other patterns exist that can be used. Longer input shafts that use larger clutches may be used by obtaining approx. .25" thick GM adapter and associated bellhousing, if desireable trans. is obtained w/ other bolt pattern. PM for px.
Rear mounts using squared U shape stock GM crossmember w/ 2 rubber mounts, single front mount, or front stock GM front crossmember using 2 rubber mounts on the frame, 1 rear mount under trans. Not a good idea to use 2 front and 2 rear mounts-frame needs to flex.
