2 members (Jay R, Donf),
71
Mod | | | Forums66 Topics128,026 Posts1,055,405 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 | I have a heater/defroster that is mounted inside the cab, not under the hood. How do you disassemble the blower motor from the squirrel cage?
Thom Masterson
| | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Do you have pictures? If it is like the ones mounted to the firewall, I believe you might need to cut out a few rivets. | | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 | I do not have pics. I have the heater box and blower motor totally disassembled...free and clear of the firewall. It's all sitting on my garage floor. The blower motor turns the squirrel cage which forces air through the heater box into the cab. The blower motor is attached to the squirrel cage but I don't know how to seperate the two. Any ideas?
Thom Masterson
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the blower cage prolly needs to come off to access screws/nuts behind it - look for some type of press nut on the end of the shaft or a set screw that has to be accessed by weaseling between the cage fins
Bill | | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 | The end of the shaft looks like a capitol D. Is that a press nut? If so, does it take a special tool to loosen?
Thom Masterson
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | On mine the screws that hold the motor housing together extend through the fan shroud and then the 2 nuts and the fan are installed.
| | | | | Joined: Feb 2010 Posts: 82 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Feb 2010 Posts: 82 | On the end of the shaft there should be a spring clip, be very careful not to break the clip, they aren't available. Some of the squirrel cages had a set screw inside on the shaft, you will need an allen wrench for those. Chances are the cage is will be stuck to the shaft, so a brass punch will drive the shaft out. | | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 | thanks...any advice on how to remove the spring clip?
Thom Masterson
