6 members (Nick in Manitou, TooMany2count, wilbur53, walter74, 2 invisible), 74 guests, and 0 robots.
Topics128,076
Posts1,055,920
Members48,429
#891560 10/23/2012 8:29 PM
Any one update the bushings on the leafsprings where thet attache to the saddles from grease bolts and pins to poly bushings?
Chris
Probably not enough room in the original hangers, spring eyes, and shackles to do so. If you want to you could change all the spring hangers to more modern type that accomidate the soft bushings, that'd be a lot of work for little improvement.
The stock pins and bushings have suited me fine, I'd rebuild/replace and leave them alone.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Agreed. I found that the bushes were a standard stock size of phosphor-bronze bush, they were cheap and I just cut them down to suit. One of the few easy jobs.
'47 Canadian RHD 1.5 ton truck
