5 members (WICruiser, Hotrod Lincoln, moparguy, Barney1951, Peggy M), 54 guests, and 2 robots.
Topics128,076
Posts1,055,920
Members48,429
#891005 10/21/2012 1:34 PM
Y
Y Offline
Hello and fist off thank you to everyone who responded to my earlier post about thinking of buying a 1951 GMC 350 2 ton. I bought the truck and she limped home at 15mph up hill. I first checked the plugs and found she was running on 4 cylinders. I replaced the plugs and wires and she ran great. Good power uphill and steady 55mph on the freeway. Last night she had enough and broke down on the freeway. First she started loosing power (back to 15mph uphill) I downshifted to second gear and she gave out. Now when I try to start her the whole truck shakes and rattles violently so I quickly turn it off. Any suggestions out there are greatly appreciated. Thanks.
-Yori
yori #891029 10/21/2012 3:48 PM
Y
Y Offline
So, I took the engine apart and found that the piston connecting rod had broken. Now just looking for parts.
yori #891203 10/22/2012 8:59 AM
That's no fun,
Consider swapping another good running engine instead of rebuilding what you have. It may or may not cost less.. depends on your luck. Properly rebuilding what you have, if it is rebuildable, can be in the $2,000 range.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #891261 10/22/2012 12:25 PM
Crusing in the Passing Lane
Depending on your needs, up to a GMC 302 will fit in there, so it might be worthwhile to hold out for one, might have a 270 now? They all look the same(228-302) on the outside.
yori #891278 10/22/2012 2:12 PM
Y
Y Offline
I've been looking around, does anyone have a source for engines?
yori #891461 10/23/2012 11:08 AM
Old farm trucks, like yours, running or not, many wrecking yard people won't know what you are talking about, just have to dream up some other reason to get into their yard and look around for yourself. GMC engines have the displacement as the first 3 numbers of the ser. no., starboard side, STAMPED on a machined pad, behind the distr.
yori #896277 11/12/2012 6:07 PM
Try Larrowe and Son truck parts
[email protected]
They have been a great help with knowledge and parts for me and my 49 GMC COE. All they do is 6 cyl GM and Chev engines. Stock or modified
yori #896372 11/13/2012 6:42 AM
-Yori
dont be thrashing it down the freeway, unless you just spent lots of dead presidents on a new motor and even though i did in all my trucks i only run mine at 50 down the free way. the reason i say this is i was in your shoes once and its not fun when your far from home. go over to oldgmctrucks. there are people there in your neck of the woods that might be able to help you out at a reasonable price.
