| | | Forums66 Topics128,045 Posts1,055,528 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 89 'Bolter | | 'Bolter Joined: Apr 2011 Posts: 89 | I have a 1954 chevy 3600 that i would like to swap a Dana 60 rear out of a 1971 c20 3/4ton into. Been having trouble finding axle width measurements etc and wont be by my truck to take measurements for another couple weeks.
Curious if this is a feasible option.
Thanks | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Try searching www.chevytrucks.org That site has charts with dimensions on various rear end swaps for AD trucks.
Drew
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | | | | | | Joined: Feb 2002 Posts: 121 Shop Shark | | Shop Shark Joined: Feb 2002 Posts: 121 | Chooglin Go to this link http://www.pirate4x4.com look in Brand Specific Tech. Under Chevy----- Got an axle question? Check here first! There is a bunch-O-reading on axles. | | | | | Joined: Apr 2011 Posts: 89 'Bolter | | 'Bolter Joined: Apr 2011 Posts: 89 | Great!
Thanks for the quick replies guys. Ill start lookin through those articles and see what i can find.
Chooglin | | | | | Joined: Feb 2004 Posts: 29,755 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,755 | I put the same unit into a 59 Suburban, and had a lot of tire-clearance problems with the rear wheel openings. The axle was about 2" wider at the wheel attachment flanges than the original rear axle. If you're running a flatbed instead of a stepside bed, the width difference might not be apparent, but I believe the early 50's track width was somewhat narrower than the 55-59 models. Jerry
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Your stock axle is going to be about 62.5" WMS-WMS(Wheel Mounting Surface). I don't know much about the Dana swap, though. I'm going to try to steer you into the 14-bolt full float direction. Most of your dually equipped GM trucks from 73 on up have 63" WMS. I purchased one that was actually 62.75". You'll have to cut and relocate your spring perches and shock brackets if you go this route though. If you can't find a dually axle you can alway use an axle from a single wheel truck and use your Eaton hubs. The Eaton hubs will give around a 65" WMS. You'll have to get creative with your brakes though. Fortunately GM has probably a dozen different options for the 14 bolt.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Getting one from a van is another option. Vans seem to run a bit narrower that trucks, I do know that one from a mid '80s Dodge van will fit without clearance problems. I do not recall the exact dimensions, as we did the swap almost 20 years ago, but we did run the truck with the stock 17" splits and 7.00-17 tires, then later with 8.00-16s with no rubbing. The truck in question was a '49 3800.
Bill Burmeister | | |
