| | | Forums66 Topics128,122 Posts1,056,332 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 78 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 78 | I have a nice 3 wire turn signal switch that came with my 51 3100 it screws to the column and has a off white plastic end for the lever. I would like to use this for my restore but the wire suplier says i need a new 7 wire. has any one over come this and used the original for full function front and rear signals. Lou
1951 chevy 3100 short bed frame off resto.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | A 3 wire switch requires separate lights for the signals. If you want them integral with the stop lights you need the 7 wire. | | |
