| | | Forums66 Topics128,149 Posts1,056,817 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 117 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 117 | Hi does anyone know if or where you can buy new bushings for the idler/reverse gear for the 3 speed trans in a 1946 1/2 thx for any help | | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | If the gear itself is not damaged, any competent machinist should be able to fabricate and install a bushing in it. He would need the gear, and the shaft it rides on to fit the bushing to the proper clearance. I've done things like that on numerous occasions when a suitable part was not readily available. Jerry
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | It may be easier to replace the gear. Here is an example on ebay ,another one
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Nov 2008 Posts: 117 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 117 | Thx for the lead Pre 68 bought the cheaper one coudn't have new bushings put in for that price and still have an old gear | | |
