2 members (PAUL Berardi, carbking), 160 guests, and 2 robots.
Topics128,081
Posts1,056,078
Members48,434
I'm going to do a t-5 swap and wondered if it's possible to change the clutch on my engine while still in the truck? I've a 1962 c-10.
thanks
1962 C-10 Chevy
More pix on Photobucket
ADHD and luvin' it
3B Offline
Hy clodstomper, yes you can remove the clutch while the engine is still in the truck, the clutch should come out of the bottom of the bellhousing after you unbolt it from the flywheel, be careful and keep your face out of the way when lowering the parts out of the bellhousing, hope that helps.
Riding in the Passing Lane
Absolutely. After you remove the lower cover & the trans. remove the exposed bolts from the clutch & turn the fly wheel to get to the rest of them. Then slide the clutch out through the bottom. You usually have to push the disc up in the houseing & pull the pressure plate out by its self first then the disc. Sometimes it helps to back out the ball that the fork rides on to give a little more clearance.
1972 Chevy c10 Cheyenne Super
Great! Thanks for the advice and probably have more questions later.
1962 C-10 Chevy
ADHD and luvin' it
Another question, how do I remove the clutch fork and what throwout bearing to use?
thanks again
1962 C-10 Chevy
ADHD and luvin' it
On my 55 the clutch fork just snaps to a ball mounted inside the bellhousing.
You need to use a TO brg. to match the pressure plate. You need a special disc to use with the T-5 so you may not buy a complete clutch kit.
I used an adapter from Dave at http://vintagemetalworks.blogspot.com/p/t-5-to-235261-adapter-plate.html and a clutch from
Richie at http://clutch-shop.com/. Both of these guys will answer any questions you have.
Larry
