5 members (klhansen, 52Carl, 55shaker, Shardean, Ponchogl), 87 guests, and 3 robots.
Topics128,022
Posts1,055,352
Members48,420
#889783 10/16/2012 11:12 AM
I'm looking for a tool that can be inserted into a bushing that can then expand to grab onto it and remove it. It's for the bushing on the spout of a kitchen faucet. Might be about 1" i.d.
Thanks.
cisz #889803 10/16/2012 12:36 PM
Remove by unscrewing or a straight pull?
1952 Chevrolet 3800 pickup
---All pictures---
cisz #889829 10/16/2012 3:28 PM
Seems like a faucet bushing would be threaded in. With a cross cut tooling notch to remove it.
A pressed in bushing, like in a flywheel use a Slide Hammer Puller. I usually rent/onloan one from the autopart store. I have even made a puller out of a carrage bolt on a grinder. ground the bolt head to fit and grab & a washer on a socket to pull into.
cisz #889919 10/16/2012 10:10 PM
Sounds like a job for a pilot buching remover.
It's threaded in. There's no cross-cut slot. It does have notches along the inside that go about 1/2 the length. (It's about 2" long.
cisz #889948 10/17/2012 12:34 AM
there's a funky little tool that comes with some faucets new that most plumbers would probably have in the bottom of their tool box - use a flat blade screwdriver that will fit snug and it should be easy to turn it out
cisz #890678 10/20/2012 1:26 AM
Sir Searchalot
Sir Searchalot
Washer cut in half, two rivets to stick out/down into notches, weld a handle on the washer or slots to tap it around or vice grips or two rivets sticking up close together for a bladed screw driver or.... This is called a spanner wrench. Maybe you can use the whole washer, you didn't say what kind of access you have. Needle nose pliers? retaining ring pliers? New faucet?
cisz #890807 10/20/2012 6:08 PM
Why not phone you local plumbing wholesale place?
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
cisz #895224 11/07/2012 8:30 PM
mo Offline
buy a new faucet probably cheeper and easier then fixing the old one
MO's 1951 chevy 3100 resto mod project
Moderated by  MNSmith
