4 members (J Lucas, Otto Skorzeny, Ponchogl, 1 invisible), 92 guests, and 2 robots.
Topics128,072
Posts1,055,903
Members48,429
#889871 10/16/2012 7:18 PM
I have the original master cyl. under the floor boards on my 1950 4100. It is the single port master. what order should I bleed the brakes?
Always bleed the farthest wheel cylinder first. Then move to the next closest.
Red dot, center of chest ...
IOW, right rear, left rear, right front, left front.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
Per the manual, Hydrovac slave cylinder, Hydrovac valve, Left rear rear wheel cylinder, Left rear front wheel cylinder, Left front wheel cylinder, Right rear rear wheel cylinder, Right rear front wheel cylinder, Right front wheel cylinder, then re-bleed the Hydrovac slave and valve. See manual page here.
For most rwd vehicles, either single or dual master cylinder, the general rule of thimb is to bleed the longest line first, not neccessarily the wheel furthest away from the master cylinder.
Bill Burmeister
