3 members (BC59, 2-Ton, Forty9), 104 guests, and 3 robots.
Topics128,128
Posts1,056,685
Members48,452
#889769 10/16/2012 10:33 AM
When I removed my instrument panel recently, I noticed a big rust hole where the wiper drive arm passes through the firewall. So I removed the cowl vent, disconnected the wiper arm linkage from the cowl, disconnected the linkage from the motor, and...the motor fell in the floor. HA! I didn't realize the mounting bracket was completely rusted through and not attached.
With the motor removed, it looks like this. The 3-prong connection was hooked up to wires, but the 2-prong connection was not. I did notice another free-hanging, loose connector in that bundle of wires.
So here’s what I’m wondering…
Was the mounting bracket welded to the underside of the firewall?
Is the 2-prong connector for the washer pump?
I’ve seen refurbished units available on LMC Truck. Has anyone rebuilt ther own?
Darren
1969 Chevy C-10 Fleetside
Darren
apparently the problem with copy/paste is still among us, you need to try typing your post directly in the text box here, not pasting it from elsewhere
