0 members (),
108
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 12 New Guy | | New Guy Joined: Aug 2012 Posts: 12 | I have a 1957 series 3100 step side short bed with a 235 straight 6 cylinder motor. I would like to convert it to power steering but can't seem to find a conversion kit so far. Any info or help will be greatly appreciated. Thanks, Roller | | | | | Joined: Sep 2012 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 45 | | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | If you're running a generator you can use the power steering pump that goes behind it. For an alternator setup call Buffalo Enterprises or JJ Inlines.
regards, Leon | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | You also have to have the correct generator with the output shaft on the back for the power steering pump don't you? | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | I expect you're right. I apologize. Poor phrasing on my part.
I meant that the generator could be replaced with a gen/pump combo. I didn't mean to imply that you can add a pump to the stock generator.
regards, Leon | | | | | Joined: Oct 2012 Posts: 4 New Guy | | New Guy Joined: Oct 2012 Posts: 4 | New to the forums. I have a 51 3100 that I need to upgrade the steering on in anticipation of a sbc swap. I'm keeping the staight axle for now & I want to upgrade the steering box to a later model power unit and move it to the outside of the frame. I wouldn't mind using drop spindles also, But I can't seem to be able to locate any. Are they available, or maybe interchange with a car? Any suggestions? I greatly appreciate any info anyone can provide. Thanks, Bob | | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | I put the CPP kit on my 51 3105......
A great improvement and pretty easy to install... minimal welding. Highly recommend using their upgraded tie rod/tie rod ends/and stabilizer bar at the same time. Since I have a panel truck I also installed a "Rough Country" sterring stabilizer on the straight axle.
I did not change spindles, tho.
