6 members (Dennys28, HandyAndy, Ridgeback, WICruiser, Peggy M, UtahYork), 119 guests, and 3 robots.
Topics128,042
Posts1,055,516
Members48,424
#888515 10/10/2012 3:58 PM
I have a 1957 series 3100 step side short bed with a 235 straight 6 cylinder motor. I would like to convert it to power steering but can't seem to find a conversion kit so far. Any info or help will be greatly appreciated. Thanks, Roller
Click the link to see my truck.
http://smu.gs/OuBwfv
If you're running a generator you can use the power steering pump that goes behind it. For an alternator setup call Buffalo Enterprises or JJ Inlines.
regards,
Leon
You also have to have the correct generator with the output shaft on the back for the power steering pump don't you?
I expect you're right.
I apologize.
Poor phrasing on my part.
I meant that the generator could be replaced with a gen/pump combo.
I didn't mean to imply that you can add a pump to the stock generator.
regards,
Leon
New to the forums.
I have a 51 3100 that I need to upgrade the steering on in anticipation of a sbc swap.
I'm keeping the staight axle for now & I want to upgrade the steering box to a later model power unit and move it to the outside of the frame. I wouldn't mind using drop spindles also, But I can't seem to be able to locate any. Are they available, or maybe interchange with a car?
Any suggestions?
I greatly appreciate any info anyone can provide.
Thanks, Bob
I put the CPP kit on my 51 3105......
A great improvement and pretty easy to install... minimal welding.
Highly recommend using their upgraded tie rod/tie rod ends/and stabilizer bar
at the same time. Since I have a panel truck I also installed a "Rough Country"
sterring stabilizer on the straight axle.
I did not change spindles, tho.
