2 members (elhippie64, 1 invisible), 80 guests, and 1 robot.
Topics128,022
Posts1,055,361
Members48,420
#88897 10/24/2004 12:49 PM
I'm pretty sure this question has been asked before but couldn't come up with anything when I did a search. Question is: How do you remove the ignition switch and lock from the steering column? This is in a rod and I'm not sure what year it is, but probably 70's vintage. Thanks, Don
#88898 10/24/2004 8:08 PM
Are you trying to repair what's there, or eliminate it altogether? The switch assembly is down about halfway to the floorboard, on top of the column. There's a round rod from the column lock cylinder to the switch assembly. To remove the lock, you have to pull the steering wheel, use a special hold-down clamp on the steering wheel lock plate to remove a lock ring, and then remove the turn signal switch assembly. Early lock cylinders had a spring-loaded tab that could be pushed down to release the lock cylinder, while later models had a hardened steel bolt with a Phillips or Torx-head screw retaining the lock tumbler. The spring latch on the first-model lock columns is sometimes concealed under a thin flashing left over when the diecast lock housing was made, and has to be probed for with a thin-bladed screwdriver.
#88899 10/25/2004 10:48 AM
Jerry, I am trying to remove the cylinder lock assembly to clean it up and repair it if possible. When I turn the key to the spring loaded start position it wants to stay in that position rather than return. Also want to replace the turn signal handle if I can get the plastic material surrounding the steering column off.
Thanks for your reply, Don
#88900 10/26/2004 12:04 AM
The lock cylinder has a bad habit of getting gunked-up and sticking. If it's had much use, you're probably money ahead to replace it while you've got the column dismantled. Just about any good parts store will have a replacement cylinder in stock, with keys.
