Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Tyler Watts, Otto Skorzeny, BC59), 160 guests, and 3 robots.
Topics128,281
Posts1,058,464
Members48,490
Page 1 of 2 1 2
#876425 08/21/2012 11:53 AM
1 Offline
Bought as a wreck, my burb is having some love from the crew at Starlite Rod & Kustom before setting sale back to the UK
Is this the first ever convertible burb ;-)
Link's not working for me...... headscratch
More pix on Flickr.
meneeder
Don
1950 Chevy Panel Delivery. Purchased in 2008 that was in a family for 35 years. Restomodded in 2006.
DonA #876920 08/23/2012 10:17 AM
Dangit, I canna see it! Often I've thought about cutting the top centre outta my bus, but then common sense sadly prevails when I realize where I live, and how it rains so much.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Link doesn't work for me either.
1951 3100 Chevrolet
That's odd as I can see it,,,,,
Wow....
that's a whole lot of work to take a complete roof off but sometimes you gotta do what you gotta do .
Good job and keep up with the progress pics
This was the first " Suburban " that I have seen converted into a convertible.
Wow! That's pretty ugly!!
Do you have to be a member of the Jalopy Journal to see that first link? If someone downloads and mails me that photo, I'll post it.
1 Offline
wierd. I got it working for me. I'll look into it
1 Offline
What is your definition of resto?
1 Offline
The way I see it is why get an only mildly rough burb that I'll still end up restoring every part of. Best to just get an honest one and not pay for parts that I will never use.
Yeah it's rough but it has a lot of the rare parts still on it.
1 Offline
Mustang front all in, ready for air-ride. Custom made rear end for maximum clearance
[IMG
1 Offline
Ssingo,
I am a "keep it natural/original" type. But, your project greatly impresses me. Keep at it.
cletis's question is directed to the dictionary definition of the word "restoration".
Your effort looks to me to be a monumental resurrection.
1 Offline
Haha, okay I'll settle with monumental resurrection. Tim,
Yeah, I like keeping it natural but now I've sold my olds lowrider and about to sell my truck I wanted something that would combine the fun I have from both. Something that could look stock from far distance but that I could also have slammed if I wanted.
best of both worlds ;-)
1 Offline
Finally the 'burb sits down low
click for pics
1 Offline
It's proving interesting working across countries when it comes to deciding on a suitable mix for 'Thistle Gray' for the engine bay and the 'blue/gray' for the engine.
If anyone has an exact code I could use it would be well handy. I have tried all the other ppg codes that an internet search brings up but alas I can't get them in the UK
Thistle gray spray up
1 Offline
[IMG
1 Offline
Finally got my roof in the same state. It's come from Michigan to Phoenix and now to Starlite Rod & kustom. Let the lead loading begin
UPDATES ON STARLITE ROD & KUSTOMS PAGE
If you are still looking for Thistle Gray codes:
DUPONT 93-70397
PPG 30873 (obsolete) or 32660 (modern "offset")
1 Offline
ohhhhh Tim you are a star. It might be too late as I had passed on a custom code to the painters but would be interested to see how they compare. Cheers
1 Offline
Chuffed at the results of my extensive donor roof research. Mad, considering it came from a car a few thousand miles away from mine (also a few thousand miles away, but in the other direction)...AND IT WAS GMC AND NOT A CHEV
CLICK TO VIEW UPDATE AT STARLITE
" . . it came from a car . . "?
I am confused regarding your comment about "donor roof research" and Chevy vs GMC. Are you referring to 47-53 Chevrolet vs GMC Suburban roof parts?
Tim To clarify, I sold Ssingo a roof from a 52 GMC burb that I parted out. I delivered it from Mich to Az. and the guys from Starlite Kustom came from Calif. and picked it up. It looks like the original roof. NEAT!!!!!!
Yes, from 47-53 all the burb roofs should match up.
Congratulations.
great lookin project
Chopped '55 Suburban
1 Offline
If i knew that before Tim, i wouldntnt of biten my fi gernails down worrying whether it would even fit when delivered. Alas, now its all together it is perfect thanks to oldburbs
Do you hear the drum roll, Sssingo?
If the "new" roof has been installed, let's see a photo or two?
I am counting on all 55.5-58 3100 Panel roofs matching. While not in emergency mode, I am looking for a donor for eventual roof replacement for my 57.
Jimi J
Jimi, the 55.2 to '59 burbs and panels share the same roof, but count on needing some massaging to match up the roof from one truck to another, especially different years - the best fit would probably involve splitting off the roof stamping at the rain gutter and the leaded joints front and back
So, that relates to my body man saying I will learn how to "drill", or something, to the spotwelds located in the edge gutter?
If the roof is attached to the sides with spot welds, you'll be cutting/drilling out the spot welds (if you plan on doing this the way it were done at the factory).
Wivco (Spot-Eze brand) makes excellent spot-weld cutting tools/bits
Looks like a great assortment of tools for the purpose.
Do those specialty bits require pilot-holes first?
My body guy says he has one of the "good old" spot welders made for body work specifically,
to put he roof back together.
1 Offline
Yes, myroof was unleaded front and rear then just spot welds drilled from the rain gutters. Ill put some pics up soonist
1 Offline
The SubURBAN laid out.
Latest pics
I'm still it the process [IMG
1937 Chevy 1/2 ton panel
1 Offline
Wow! more major works. how comes you needed to new donor?
Apparently a tree had fallen on it.The entire wind shield and drivers door frame were twisted beyond repair(at least for me)
The left over parts could make a good rat rod.
Page 1 of 2 1 2
