4 members (TooMany2count, MNSmith, moparguy, TexasJim50), 56 guests, and 5 robots.
Topics128,014
Posts1,055,324
Members48,419
#888222 10/09/2012 4:14 PM
Ok, got axel back under, seals, bearings, tie rod and all linkages hooked up with hub on. Grabbed hub at 3&9 and wiggle, I've got about 1/8 inch movement at pitman arm is this normal?
If they don't find you handsome,they should at least find you handy! ~ Thanks RED GREEN
1957 Chevy 3800 :: In the Stovebolt Gallery
More pix on Flickr
Duwop #888341 10/09/2012 9:59 PM
I guess that you are saying you have angular movement of the Pitman arm which is a steering box issue. What does it translate to in the steering wheel with the wheels point directly forward?
1951 1 Ton Completed
Duwop #888405 10/10/2012 8:18 AM
With wheels forward, there is no movement in the steering wheel.
More pix on Flickr
Duwop #888432 10/10/2012 10:12 AM
bad/worn drag link?
1952 Chevrolet 3800 pickup
---All pictures---
Duwop #888453 10/10/2012 11:13 AM
Thanks Grigg that gives me a starting point. Will check manual
More pix on Flickr
Duwop #888481 10/10/2012 12:47 PM
Checked tie rods, third arm/drag link and am missing nylon grease caps but all accepted grease and are not loose. If I grab pitman arm I can move it 1/8 inch either way but no further. Maybe worn sector shaft in gear box?
More pix on Flickr
Duwop #888510 10/10/2012 3:00 PM
Have you checked the sector shaft adjustment?
Bill Burmeister
Duwop #888525 10/10/2012 4:34 PM
No, is it described in manual. I will look, Thanks
More pix on Flickr
Duwop #888534 10/10/2012 5:08 PM
Yes, the procedure is describens on the manual. It's a relatively easy procedure, and sounds from the description you give of what's going on, the part that needs adjusted.
Bill Burmeister
Duwop #896949 11/15/2012 5:53 PM
Thanks longbox55, read manual and will give that a shot before anything else. taken a brake cant get the wife or kids to help bleed brakes, been waiting on them four weeks now but have been restoring steering wheel, and grinding old paint in the meantime.
More pix on Flickr
Duwop #896978 11/15/2012 9:02 PM
I bled my brakes by myself using a bottle and tube as described in the manual.
Duwop #897141 11/16/2012 5:02 PM
please explain,I read the manual i must have missed something. Ill look again.
More pix on Flickr
Duwop #897192 11/16/2012 7:58 PM
Here isn the photo and the explanation. Bleeding Brakes Manual Method
Duwop #897246 11/16/2012 11:07 PM
back yard wrench turner
W Online: Content
For one person brake bleeding, use 'speed bleeders'. I bought mine at NAPA.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Duwop #899197 11/25/2012 11:11 AM
I've got other issues now, got some help but can't seem to get any peddle. So I've been trying to find leak, I suspect the MC but will figure it out another day.
More pix on Flickr
Duwop #901461 12/05/2012 6:03 PM
Got it all fixed and bleed. Took her for a ride, 50 mph top speed ,wanders a little but will work on that. On the road again, not perfect but darn close. Thank for all the help.
More pix on Flickr
Moderated by  Dusty53
