| | | Forums66 Topics128,154 Posts1,057,014 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#88814 03/04/2002 5:32 AM | Joined: Aug 2000 Posts: 13 Junior Member | | Junior Member Joined: Aug 2000 Posts: 13 | Two questions on a "59" Apache. 1) Were turn signals an option for that year? 2) My manuals wiring diagram does not show any turn signal info, but I know that there are parts available (stock). Does anyone have a wiring print that shows the original wiring and or a breakdown of the steering column components? | | |
#88815 03/04/2002 6:46 PM | Joined: Mar 2001 Posts: 77 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 77 | 59 hummm i thinks they had turn signals. hey i got this diagram chief posted hope this helps
i thinkzz traveling along at terminal velocity will soon wear a body out. i will not die in shame if i never finish my dreams because my family iz my reality
can't wait until we can bed de ponys down, lite de fire, put on a big ol pot of coffee, and talk about how strong and brave our teams are.
bullfoot thinkszzzzzzzzzzz
#88816 03/05/2002 3:54 AM | Joined: Sep 2001 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2001 Posts: 85 | I dont think turn signals were optional in '59. The factory manual shows wiring diagram for trun signals, but it is hard to read. If you cant read the diagram posted by Bullfoot, send me a Fax # and I will fax you a diagram I got from a vendor when I purchased a new t.s. switch. It is not much better, but you can make out wire colors.
Did you have a specific question about the T.S? | | |
#88817 03/05/2002 3:58 AM | Joined: Mar 2001 Posts: 77 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 77 | sorry the picture trail thing my pic are on are automaticly resized and should have much bigger
#88818 03/05/2002 5:11 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | msteuer - factory turn sigs were an xtra cost option in the task force. the wiring diagram came with the unit. pretty straight forward. the large plastic wiring connector for it should be under the dash by the steering column, and the unit just slides on the column under the wheel with the wiring going down the column w/ the horn wire. I could send ya some pics if ya want. could probably send ya a whole unit, but Joy might get excited! Bill  | | |
#88819 03/05/2002 2:52 PM | Joined: Aug 2000 Posts: 13 Junior Member | | Junior Member Joined: Aug 2000 Posts: 13 | You guys are great. Thanks for getting back to me.  | | |
#88820 03/05/2002 2:55 PM | Joined: Aug 2000 Posts: 13 Junior Member | | Junior Member Joined: Aug 2000 Posts: 13 | RED58: If you have anything To help me along with the installation I'd appreciate it much. | | |
#88821 03/05/2002 5:47 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if you can find the "cup" w/ the basic insides, the switch is available as reproduction. here\'s a pic of the works . the scarce part is the plastic cover for the switch side of the wiring - has to be off to get the wires thru the column, so it's usually lost! need more? Bill | | |
#88822 03/05/2002 7:15 PM | Joined: Aug 2000 Posts: 13 Junior Member | | Junior Member Joined: Aug 2000 Posts: 13 | RED58; Thanks again. I believe I have an origional on the way at this time. Now to see if the cab is pre-wired to accept it.( my original option question) | | |
#88823 03/07/2002 11:11 PM | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | According to my original '59 Chevy Truck Data Book, directionals were an option in '59 and they were redesigned from the '58 trucks to meet certain state requirements. These are available as a truck accessory from the factory and not as a "regular production option". The distinction is that accessories were dealer installed where RPOs were factory installed generally speaking. | | |
