0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#887986 10/08/2012 8:52 PM
I have a 1952 3100 frame, just installed my "55' 235 on the frame and ready to install the clutch. I am using the bell housing from my 216 so the rear mounts were the same. The clutch arm and throw out bearing should work fine I expect. I am using the fly wheel from the "55" with electric start starter to eliminate the foot start. The shop manual states to line up the x on the flywheel with the x on the clutch assembly. I cannot find an x on the flywheel. Is this a problem if I just put the clutch assembly back on with out lining this up.
If you never tell a lie, you never need to remember what you said.
Can you find the x on the clutch assembly?
http://s1055.photobucket.com/user/baldybenny/library/
1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
Yes, there is an x on the clutch assembly.
Bart_Bosco #888014 10/08/2012 10:02 PM
That only applies to original-equipment installations that were factory-balanced. Once the clutch and pressure plate gets changed, where the clutch cover gets positioned in relation to the flywheel is immaterial.
Bart_Bosco #888028 10/08/2012 10:26 PM
Thanks for the reply.
