| | | Forums66 Topics128,030 Posts1,055,418 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 133 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 133 | I have a 1952 3100 frame, just installed my "55' 235 on the frame and ready to install the clutch. I am using the bell housing from my 216 so the rear mounts were the same. The clutch arm and throw out bearing should work fine I expect. I am using the fly wheel from the "55" with electric start starter to eliminate the foot start. The shop manual states to line up the x on the flywheel with the x on the clutch assembly. I cannot find an x on the flywheel. Is this a problem if I just put the clutch assembly back on with out lining this up.
If you never tell a lie, you never need to remember what you said.
| | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | Can you find the x on the clutch assembly? http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Dec 2011 Posts: 133 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 133 | Yes, there is an x on the clutch assembly.
| | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | That only applies to original-equipment installations that were factory-balanced. Once the clutch and pressure plate gets changed, where the clutch cover gets positioned in relation to the flywheel is immaterial. Jerry
