5 members (Brian Moore, Jims46, Sedgewick, walter74, J Lucas), 63 guests, and 2 robots.
Topics128,030
Posts1,055,423
Members48,422
Page 2 of 2 1 2
#88784 02/20/2004 5:13 PM
Did not have a template when I did it. Can't really see why a template is really that necessary. I first placed the outside bracket against the pillar, put a large drill bit that was a snug fit in and viewed how many degrees off horizontal it was. Removed everything, got the ole drill out with a small drill bit, as carefully as possible tried to drill into the pillar at same angle. No not rocket science technology but it worked pretty good.
The hardest thing was getting myself to turn the drill on. The idea of poking a hole right there made me sweat a little. eek
Craig
#88785 02/21/2004 3:07 AM
The template locates the bracket a certain distance from the belt line and a certain distance from the door channel. I can tell that you didnt use the template on yours because it is higher up than mine.
#88786 02/24/2004 5:28 PM
Maybe I didn't drill in the spot per the template but copied the same location as per my '53 (which the spotlight came from).
Besides, guess whose spotlight made the Stovebolt calendar???? grin
http://www.cafeshops.com/stoveboltpage.9802559?zoom=yes#zoom
Craig
Page 2 of 2 1 2
