8 members (Bill Hanlon, Waveski, Jon G, Pre '68 Dave, 3B, kades51, 2 invisible),
126
Mod | | | Forums66 Topics128,283 Posts1,058,513 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 29 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 29 | Hello everyone. I am new to this forum and would appreciate some advice. I would like to get my 55 second series truck going. The original engine is no good, I got a quote for $1700 to rebuild it. I found someone selling a 56 235 engine that came out of a sedan. It comes with the power steering pump so I am assuming it was mated to automatic Trans. I want to keep my original three speed Trans. He is asking 500. Would this be an easy swap? Anything I need to look out for? I will have a friend doing the engine swap. Thanks in advance. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Welcome to Stovebolt.com
"Newer" car engines are often used as replacements in older trucks.
All 1956 engines in cars supposedly had hydraulic lifters. All truck engines had mechanical/solid lifters. The car engine can somewhat easily be used in a truck.
Someone else will correct me, if necessary, and maybe add information about the front motor mount.
Power steering (RPO 324) and Powerglide (RPO 313) were separate options on cars: you could have one without the other.
If the engine came with a Powerglide, you would want to use your truck's starter, clutch housing, and clutch assembly.
$500 would be a good price for an engine with good compression and good oil pressure. Does the seller know the oil pressure and the compression readings?
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Should be an easy swap. 1955-57 pass engines will have the needed front side mount provision needed to install in your 55 second. In addition to what Tim said you will also need to install a pilot bushing in the rear of the crank.
See the USA in your vintage Chevrolet! My Blog | | |
