1 members (k2handyman),
74
Mod | | | Forums66 Topics128,030 Posts1,055,418 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#88784 02/20/2004 5:13 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Did not have a template when I did it. Can't really see why a template is really that necessary. I first placed the outside bracket against the pillar, put a large drill bit that was a snug fit in and viewed how many degrees off horizontal it was. Removed everything, got the ole drill out with a small drill bit, as carefully as possible tried to drill into the pillar at same angle. No not rocket science technology but it worked pretty good. The hardest thing was getting myself to turn the drill on. The idea of poking a hole right there made me sweat a little.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#88785 02/21/2004 3:07 AM | Joined: Jan 2002 Posts: 32 Member | | Member Joined: Jan 2002 Posts: 32 | The template locates the bracket a certain distance from the belt line and a certain distance from the door channel. I can tell that you didnt use the template on yours because it is higher up than mine. | | |
#88786 02/24/2004 5:28 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Maybe I didn't drill in the spot per the template but copied the same location as per my '53 (which the spotlight came from). Besides, guess whose spotlight made the Stovebolt calendar???? http://www.cafeshops.com/stoveboltpage.9802559?zoom=yes#zoom
