| | | Forums66 Topics128,126 Posts1,056,356 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 12 New Guy | | New Guy Joined: Aug 2012 Posts: 12 | I have a 1957 Chevy 3100 Series truck. I removed the 3 screws holding the instrument bezel to the dashboard but can't get the bezel off to replace the old speedometer glass. Please let me know what else I need to do to remove the bezel so I can remove the old speedometer glass and replace it. Thanks, Roller | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | welcome to the garage Roller, and welcome to one of the more frustrating areas to deal with on the Task Force series  you need to remove the whole gauge cluster from the dash [that's what those 3 screws are for] and on the back you'll find a whole bunch more fasteners that hold all the bits together .... go slow and you'll get it all figured out, usually the top of the cluster needs to come out first [tilt forward] and it may take a bit of prying to get it Bill | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | red58 is right on, those are a booger to get out sometimes.
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Jan 2011 Posts: 152 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 152 | What I found on mine was the oil pressure tube. The tube was not very long but follw it from eng. compartment to under/behind dash and one hand on cluster, other hand under/ behind work forward enough to remove oil tube nut. | | | | | Joined: Aug 2012 Posts: 12 New Guy | | New Guy Joined: Aug 2012 Posts: 12 | So if I am understanding this. The whole instrument cluster needs to come out of the dash just to replace the plastic face behind the bezel. Please confirm. Thanks again --- Roller | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | confirmed, the whole cluster is a pre-assembled unit held together from the back side
Bill | | | | | Joined: Aug 2012 Posts: 12 New Guy | | New Guy Joined: Aug 2012 Posts: 12 | | | |
