| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#88744 11/27/2003 6:30 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | While waiting for the turkey to be put in the oven, I thought I would relay my limited experience on installing a Unity Spotlight so others who are considering this can hopefully learn either what or what not to do. Mine is a S6 with the overall length being about 14". Diameter of exposed glass is 5 1/2" diameter. This light came off of my '53 which was crushed by my front oak tree years ago. It was one of the many items I salvaged and decided to install onto my '50. I had to drill a hole through the corner cab pillar which made me sweat just thinking about it. The mounting brakets that fasten to the cab are angled so they sit flush against the cab. The angle you drill has a direct affect on how well these brackets (especially the outside one) sit flush against the cab, so give it a lot of thought. On the inside of the cab the spotlight shaft interferes with the interior windlace (if you have this). The hole comes through the windlace channel so I had to remove my windlace material, drill the hole, straighten up the part of the channel that was disfigured by the drilling. Did a test install to see if everything went in ok and fastens down well without having the windlace installed. Afterwards (assuming all went well) I removed the light, installed the windlace, notched out the portion of the windlace that interferes with the hole. FYI, I find using lots of talcum powder helps slide the windlace back into place. Afterwards, I re-installed the light which was a snug fit due to the resistance of the remaining windlace which I had to trim a little bit more. Bolted everything down and connected the wire to a positive lead I believe on my headlight switch. Looking at my light, I could possibly trim about 2" off the shaft if I wanted to shorten it up a little but since it's not giving me bloody knuckles at this point, I'll probably leave it alone. Here's a couple shots for reference. http://community.webshots.com/photo/102029454/102029877iKqHdf I'd love to hear other experiences and suggestions on this so those planning to do this can benefit. Happy Turkey Day
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#88745 11/27/2003 6:39 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I haven't installed mine yet. I found a shorter than yours on Ebay after some looking. I understand there is an installation kit from Unity with a drill guide that should make drilling the angle easier. I will order it when I get close to mounting my light.
54 3100 with 235 62 flatbed dump C60 with 261
#88746 11/27/2003 6:51 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Tony M, I wish I had a drill guide back when I did mine. Hope all is well...
Craig
#88747 11/27/2003 8:28 PM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | This is great ... I'm really interested in installing one on my truck.
1- What about the RED lights? What's different about them?
2 - Looks like I shouldn't order one that's any less than 12-inches - right, Craig?
3 - I'm wondering where the handle sits in the interior. Does anyone have a pic that shows the interior position?
4 - Can you mount these anywhere other than the corner cab pillar? Or would you want to?
5 - Can anyone post a copy of the drill guide?
I'm waiting to hear from one eBay seller who seems to have everything in stock, including different mounting brackets, etc. ... I'm wondering if I can just order from him and get extra bulbs, etc. -- if I get the drill guide, I'll scan it and post it.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
#88748 11/28/2003 2:12 AM | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | I bought my spotlight on ebay. It's a Firestone spotlight, made by Appleton. I fastened the outer bracket to the windshield post and used it as a 'guide' to keep the drill level. The handle is quite long, but it's not in the way. The handle matches the radio buttons nicely... | | |
#88749 11/28/2003 2:12 AM | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | Who's the old grey-haired married guy in the mirror?  | | |
#88750 11/28/2003 2:32 AM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | "Mom, where is dad?" -- "He is in the garage again playing with his spotlight..."
#88751 11/28/2003 3:10 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Hey, Craig
I just saw the interior shots ... I'm thinking if you mounted it a bit higher, you wouldn't have had a problem with the windlace -- the pillar gets a little wider as you go up, right?
Has everyone mounted theirs in the same position as Craig's? Anyone go up higher? Seems like it could be mounted a lot higher and still be cool, eh?
#88752 11/28/2003 8:22 AM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Let's clarify a couple issues: The grey hair was done on purpose to look distinguished when working on the truck.
The fake wedding band was put in place to help keep female stovebolters from getting any wild ideas of marrying me for my truck.
The kids don't ask where dad is. They KNOW where dad is, in the garage with his 4 wheeled mistress.
Alan, the pillar width remains the same all the way up another 9+ inches. It only gets wider at the very upper corner of the glass.
Craig
#88753 12/02/2003 3:00 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | Good job, now you need one on the other side...Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#88754 12/02/2003 3:33 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | joker,
It's too dangerous having another one installed on the passenger side pillar (although that would look nice). The "Portable Hand Spot Lamp . . . with 12-foot cord which plugs into the cigarette lighter" can be safely used by the driver without having to reach over to a pillar-mounted controller on the other side of the cab.
Tim | | |
#88755 12/02/2003 4:12 AM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Why can't the passenger operate the passenger side mounted spotlight?
#88756 12/02/2003 4:32 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | No problem, if you have a passenger.
The Portable Hand Spot Lamp also provides coverage in all directions. But, it does not look as nice as dual pillar-mounted spot lamps (Safety Lights).
Tim | | |
#88757 12/02/2003 4:53 AM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Personally I don't think two looks good. A bit too much of a good thing.
#88758 12/02/2003 5:00 AM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | it is a norm, dual spot lights, I thought that you were speaking of the 50's type, dual exhaust, two of anything is better then one, you know that Tony m, you have twin daughters,,,Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#88759 12/02/2003 8:19 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Check this out -- I just copped a Unity S6 from Ebay for $15.52 ... hehehe! Not bad, eh? Now I have to get the mounting brackets. PS - I also have to determine if it's 12 volt or not (and if it works) ... but I figure it's a good set of spare parts (for $15) if nothin' else, right? But since it's an S6, doesn't that mean it's 12 volts??? [img] http://AlanHorvath.com/54chevy/chevypics/unityS6.jpg[/img]
#88760 12/02/2003 8:26 AM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | It will change from a 6v to a 12v with the twist of the bulb.
#88761 12/02/2003 11:46 PM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Ah-haa! So it's just the bulb that matters, eh? Cool.
I think I'm also gonna need mounting brackets and the rubber that goes with them ... does anyone have a source for buying bulbs and stuff like the mounting brackets? Or do I just watch eBay?
Thanks.
#88762 12/03/2003 12:11 AM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | If it is a Unity they are still in business and sell everything. I also need the installation kit and bracket. There was some place that also sold decent foglights that carried everything. I will look for the link. Someone might chime in.
#88763 12/03/2003 12:14 AM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I think this was it. Kantors
#88764 12/03/2003 5:25 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Perfect! Thanks, Tony. The cool thing about buying new brackets is getting new rubber, too. I'm gonna have to put a pair of those fog lights on the front of my truck after I do the spotlight install -- they'll really match up nice I think!
#88765 12/03/2003 6:25 AM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | You guys act like spotlights are a crucial part of a truck or something. You're right. Of all accessories, it stands out a lot. Just make it work as well as it looks.
#88766 12/04/2003 3:39 AM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Just ran into the actual Unity website. Unity
#88767 12/04/2003 1:22 PM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Hey, Craig
I agree! A spot on the driver side is a beautiful sight to see ... and if it didn't really work, it would be a total shame.
I'd like to see a photo of a 54 with two fogs on the front ... just to see if it's good looking or overkill???
#88768 12/04/2003 5:38 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Tony M That Unity site is pretty cool. They have an archieve section that tells you what light was normally used on what vehicle.
Good info
#88769 12/05/2003 4:44 AM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 |
#88770 12/05/2003 9:24 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Eeee-haaa!!! Oh, MAN ... is that sweet looking! Thanks, bro' -- that's a GREAT set of photos, Craig.
#88771 12/05/2003 3:10 PM | Joined: Nov 2001 Posts: 182 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 182 | | | |
#88772 12/12/2003 6:38 AM | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | Craig,
Now you went and did it. Your photos did me in. I had to go dig out an old Unity a neighbor gave me about 25 years ago. Still brand new in the box. Even turned out to be the right one for AD's,#225 B, about 12" long overall. Just have to get an install kit,(has one in the box but not the right one).
Did you put a fuse in the power line to the light? | | |
#88773 12/15/2003 5:24 AM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | brjr51, No fuse though I should probably install one.
#88774 12/15/2003 11:33 PM | Joined: Jan 2001 Posts: 230 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 230 | FWIW , Alan's spot light is the current production one , sweet talk at most City garages will get you one taken off a police car salvage unit . most scrap yards have boxes of these things . the correct ones have white (more or less) handles and the head is slightly different too .
the one in the 1st. pic is the wrong one for an AD as the shaft is too long , the correct one clears the steering wheel easily .
Unity still makes the " Installation Kit " and it includes the drill guide and paper template to properly position the outer bracket - last ones I bought were $6.95 list price .
When buying used spot lights , always check the gearbox in the handle for full 360* rotation as they wear out and strip occasionally .
I personnaly dig dual spot lights but am reluctant to drill my " A " pillars as they're about the only un-chingered part on my '49 .
the driver can easily reach the passenger side one but California law forbids driving with a spotlight on .
Water & Power trucks locally used the center of the cab roof mounted one , looks kinda funky to me .
-Nate There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
#88775 12/18/2003 7:06 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Hey, Nate You're right again ... as usual. The spot I bought on Ebay looks fine, except the gearbox under the light is frozen-up -- won't turn at all. I guess I blew $15 on a quick education. It also had no mounting brackets, and after going to Kanter.com and pricing everything, I decided it would be best to buy a new unit for $143.00 ... I think I'm gonna buy two fog lights for the front of the truck (eventually), too!
#88776 12/23/2003 2:58 AM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | What's quirky about my light is that at least 2/3rd of an entire rotation the light will not stay on while I'm turning the handle but once I stop turning it comes on. This is very hard to deal with while on a coon hunt in the woods. Them critters never sit still long enough
#88777 12/23/2003 10:48 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Hey, Craig
Sounds like the pressure being exerted while turning is probably tilting the mechanism and breaking contact ... when you stop turning, everything relaxes back into position and back into contact.
Get some dielectric grease in there and maybe it'll take up the slack?
#88778 12/24/2003 4:48 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Alan, That sounds way too easy. Good idea and project during the time, the cab gets painted.
Craig
#88779 12/29/2003 5:11 PM | Joined: Nov 2001 Posts: 182 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 182 | Anyone know the correct "installation kit" for a Unity spot? (AD truck) I got a used spot on eBay...There must be others who have gone this route. Thanks! | | |
#88780 12/29/2003 5:39 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | That kit can be found at the links in the previous posts of this thread. You can get it from Kantors or Unity themselves...
#88781 12/30/2003 5:03 AM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Dang, 36 replies to this thread? Doesn't anyone have a personal life? (as if I should talk)
#88782 12/30/2003 11:48 PM | Joined: Nov 2001 Posts: 182 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 182 | Those pictures did it Craig....worth framing. | | |
#88783 02/20/2004 1:58 PM | Joined: Nov 2001 Posts: 182 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 182 | Craig...did you use a template from Unity to position where to drill the hole thru the truck? Do you still have the template? I have all the parts ready to go and don't have the template... Thanks! | | |
