0 members (), 53 guests, and 8 robots.
Topics128,021
Posts1,055,355
Members48,420
#883100 09/16/2012 8:19 PM
Is there apositive detent for the neutral position on the turn signals of a 58 Apache right now I just guess?????
on the factory unit, yes there is, if it doesn't feel "positive", one of these springs may be broken or loose .... you'll need to pull the steering wheel and look in the signal cup to see exactly what's wrong
My '59 I used to own had a "soft" feel on one of the directions. Now I know why!
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
Thank you very much, I will pull the steering wheel and check!
Well I am probaly the slowest SOB around but I checked all the springs and they are all fine it seems that there is a lock in right ore left but nothing in neutral is it in the switch or in the spring thingys?????
the switch is just a 3 position slider, the springs should give it a positive feel, especially that big one on the right in the pic, any of the springs can get weak enough to lose the 3 position feel - also check the pawls the 2 coil springs are attached to and operate it and watch the action, "neutral" is just the "relaxed" position between L and R, it should take some effort to put it in the turn positions and it should snap back when the canceling cam on the underside of the steering wheel hits the tabs on the ends of the "horseshoe" .... it should return to a center position that makes the signal staying on impossible
