3 members (Phak1, Otto Skorzeny, TexasA&M48Truck), 110 guests, and 1 robot.
Topics128,092
Posts1,056,040
Members48,433
#886802 10/04/2012 9:03 AM
A basic question here regarding converting from a 6 volt to 12 volt system .... if I currently have points and condenser in my 6 volt distributor and now changing to 12 volt system do i need to replace the points and condenser or can I run my old ones?
I always used the same ones with no problems.
You need an ignition resistor feeding the power to the coil. This makes the points last longer by reducing the arcing.
If you want more spark during starting (a good thing) you wire from the start pole (ign switch, button, etc) to the coil side of the resistor. Then 12V will flow to the coil during the time the starter is running, 6v while key on.
1951 Chevy 3600 rust bucket with GarWood dump bed conversion
http://www.flickr.com/photos/mikeybs51chevy
Thanks Cletis for the information on the condenser...
Mikeybakken - you mentioned the resistor being added. If I have a 12volt coil with the resistor built into it would I still need this added into the circuit?
thanks,
Not heard of the resistor built into the coil, would have to see the skematic of the coil to see whats going on inside.
If you get a plain old standard 12V coil, yes, again it will make your points last longer. When car and tractor companies switched to 12v all ignitions had ignition resistors. GM started solenoids had a pole that provided 12V that was wired to the coil side of the resistor. Ford ran a wife from the starter solenoid pole of the ignition switch for the same purpose.
You don't have to, just keeps the points contacts cleaner longer.
Mike
there are newer style coils that are 'internally resisted', usually it will be printed on the coil that they do not require an external ignition resistor - they work fine with any 12V conversion or on the TF and later trucks that are factory 12V - either type coil should be available at the parts stores
