1 members (UtahYork),
215
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 60 | HI guys, I am going to paint my '49 1/2 ton myself. Inside and out. Does anyone have any help on should i paint inside first or after truck outside is painted??
| | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | | | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | You've got 4 cents now, I'm for interior first. That's how I'm doing it. | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | So, you get the outside done. Now you're going to climb in and out of the vehicle, drag the air hose in and out or what ever else. Maybe scratch the outside........ I vote paint the inside first. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Definitely paint the inside first, and all your edges. Then you can mask everything off and paint the rest. It makes way more sense that way. | | | | | Joined: Apr 2008 Posts: 133 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 133 | all one color? if so, paint it all at once. i've done three trucks like this and works good, just need to be attentive to where you are at all times so as not to touch wetpaint.
daren | | | | | Joined: Aug 2011 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 60 | Thanks all you guys. Some good info and thoughts!!!!!! | | |
