1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#88634 03/12/2005 3:14 PM
Hi all, I'm having a problem getting my horn to work. The horn works when connected directly to the battery so I know it's okay. Here's what I have - a horn with 2 terminals, a relay with 3 terminals, one says "switch", one says "horn, and the third is for continuous power, and an after market horn button with 2 terminals. My EZ wiring system has a green wire marked "horn". Would someone please explain how these 3 things are all wired together. Nothing has worked for me and I'm afraid I will fry something if I keep switching wires around. Really would appreciate some help here. Thanks, Don
#88635 03/12/2005 7:00 PM
You have after market horn and switch. What is the relay?
Quote
Horns generally don't have polarity, but if it has two terminals it could. When you tested it with the battery, you connected one terminal to the hot side and the other terminal to the ground side.
The ground side terminal goes to any good ground (the body or frame).
The hot side goes to 'horn' on the relay.
If it worked either way when you tested it, it doesn't matter which terminal is which.
Quote
Horn to the 'horn' terminal as stated above.
Hot side of the power to the 'power' terminal.
'Switch' terminal to either side of your switch.
Quote
If you've followed the above, you have one switch terminal that is not connected to anything, the other goes to the relay.
If the relay is a conventional horn relay (likely based on the labels), you connect the last terminal on the switch to a good ground.
Quote
If you follow what I've outlined you can ignore the EZ connection. I've never used one so I'm just assuming I know what it is. I could be wrong....
Does the EZ harness have the plugs for a GM steering column? If you have the column and horn button the harness is designed for you might want to connect that green wire to the 'switch' terminal on the relay instead of using the switch you've bought.
If you still have trouble I'd bet your ground connections need to be double checked. Its also possible your horn relay is different, and that instead of grounding the switch, it needs to be connected to power, but that seems unlikely.
#88636 03/12/2005 10:26 PM
Thanks Oldsub for the response. The relay is also after market since my truck had no horn or relay when purchased. Yes, the EZ wiring harness fits to a GM tilt steering column but I'm not sure if the horn part of it is wired, I will check. I'll be going to the garage shortly and will follow your instructions and see if I can get a honk. Thanks again, Don
