0 members (),
79
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#88510 04/04/2005 3:21 PM | Joined: Jun 2002 Posts: 53 'Bolter | | 'Bolter Joined: Jun 2002 Posts: 53 | Brought my new, actually old, '69 C-10 home a while back and noticed that when you turn on the parking lights or headlights that the turn signal indicators in the dash light up, but the front parking lights don't work. It also looks like the turn signals are flashing the parking light filament in the front. There are no apparent crossed wires at the grill connections. Anybody got any ideas on what might be going on? I haven't recieved the wiring diagrams that I ordered yet, so I can't even use them to try to figure it out right now.
53 Dumpy
1951 Chevy 3100 "Ernestine" 1970 Chevrolet C10 "Ol' Blue" 1940 JD "long-hood" B 1959 Jeep FC-170 1960 IH B275 2013 Chevy Silverado 2023 GMC Denali 2500HD
#88511 04/04/2005 10:38 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Your parking lights probably are not grounded. Run a test lead to the base of the bulb.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#88512 04/05/2005 5:03 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I agree with wrenchbender. The power from the park light switch is running across the filament to the common side then across the turn signal filament, then through the turn indicator bulb on the dash and using it's ground. The fix could be a simple as cleaning the base of the bulbs and the sockets. If that doesn't fix it then the socket is not grounding to the frame. | | |
#88513 04/05/2005 2:21 PM | Joined: Jun 2002 Posts: 53 'Bolter | | 'Bolter Joined: Jun 2002 Posts: 53 | Don't know why I didn't think of that. Of course you realize that corrosion is not something that we have much problem with up here in the great, white north! I'll check that out as soon as I get the chance.
53 Dumpy
