7 members (Lightholder's Dad, cmayna, Guitplayer, Hotrod Lincoln, fonz8261, RLB, 52Carl),
89
Mod | | | Forums66 Topics128,192 Posts1,057,229 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | figure how much shorter you need it and take the motor to a parts store or auto electric shop and have them find one same diameter with same rotation and same shaft dia/length - if that doesn't find one, there likely isn't anything
Bill | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The Jim Carter one I bought just barely protrudes. I imagine with some alterations to the heater mounts it could work. | | |
