2 members (BC59, Danielbolt), 210 guests, and 3 robots.
Topics128,149
Posts1,056,817
Members48,454
I suspect this has been covered here before, but I am fairly new here. I have a 34 Chevy half ton pickup, with the normal 6 volt system. I am considering getting an 8 volt battery. From what I have gathered, an 8 volt battery does not harm the electricals and supposedly helps with starting. Would appreciate knowing if this is accurate, and if so, any suggestions on what to get and where? Also, any drawbacks?
Thanks. wjb
Got a 8V battery in my 36 GMC. Only minor problem that I have had has been that light bulbs don;t last as long. Does spin the starter a little quicker. grin
1936 GMC T-14 1/2-Ton Pickup
This has been covered before. You can do a search for "8 volt" and see what turns up. Some of the main points that have been covered are to the effect if your 6 volt system is in good shape and all your electrical connections are clean and good there isn't any real need for the 8 volt battery. This also take for granted the your engine and charging systems are in good opperating order. You may want to check out your charging system and cable connections before changing to an 8 volt battery.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
Short answer: NO!
Longer answer: H**L NO!
By the time you get the voltage regulator adjusted to keep the thing charged, the voltage will be about 9.5 volts, and every 6-volt part on the truck will be overloaded. it will burn points, burn out light bulbs, and go through generators and regulators like popcorn at a double-feature movie! If you're determined to get lots of cranking voltage, get two 6-volt batteries and a series-parallel switch, and put 12 volts to the starter only, none of the rest of the electrical system. It's expensive and complicated to wire, but it doesn't involve overstressing the whole electrical system, just the starter.
Folks: Thanks a bunch for all the good advice. I only wanted it for extra "umph" in starting, but obviously, that ain't a good enough reason. I appreciate the information. wjb.
