1 members (mason86),
63
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,671 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#88368 08/26/2003 8:48 PM | Joined: Jul 2001 Posts: 12 Member | | Member Joined: Jul 2001 Posts: 12 | I need advice on how to hook up a three speed standard overdrive transmission in my 62 1/2 ton Chevy truck-235 six. I plan to run wires to a flip switch in the cab instead of using the carb and governor. I would manually switch to overdrive as needed. The rest of the time I would use the standard three forward gears if I needed to pull something like a trailer or a hill. Any ideas or suggestions? The guy I bought the trans from said the flip switch will work...Thanks in advance for any ideas. | | |
#88369 08/26/2003 10:22 PM | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | Take a look at: http://www.classictruckshop.com/clubs/earlyburbs/projects/over/drive.htm specifically the picture of overdrive electrical system. Put the switch in instead of the governor. Only problem is remembering to turn off the switch when below 23 mph. Full info also available in standard shop manual for your truck. Should work fine. | | |
#88370 08/28/2003 6:25 PM | Joined: Feb 2003 Posts: 129 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 129 | Is there a specific reason for 23 MPH or is that just a figure of speach for, when you slow down you must disengage the overdrive? | | |
#88371 08/28/2003 7:05 PM | Joined: Jan 2000 Posts: 206 Member | | Member Joined: Jan 2000 Posts: 206 | The factory figured 23 mph because lugging the drivetrain is bad news for the freewheeling clutch rollers and cage. These pieces can't take much in the way of side loads, and they're difficult to locate if they need replacement. The planetary gearset also suffers from this stress. It's a good idea to wire an idiot light as a reminder that the solenoid is engaged, It's all too easy to forget and "bog" down.
The 'Burb page diagram is interesting but overly complex if you just want to control the solenoid. All that "split shifting" may be fun for a while, but a bother to do all the time. All you need is a toggle (and light) between the power source and solenoid. | | |
#88372 08/29/2003 10:14 AM | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | I was always interested as to why no one has ever considered wiring a simple push-pull switch to the gearshift lever near the knob, in a similar fashion to all the big trucks on the road. The mechanism and method is different, but the results would be the same. Close proximity to the overdrive switch when and where you need it!  | | |
#88373 08/29/2003 3:13 PM | Joined: Jan 2000 Posts: 206 Member | | Member Joined: Jan 2000 Posts: 206 | When I was running my overdrive setup, JC Whitney offered a shift knob with a momentary horn switch built in - a terrible idea but I was able to replace that switch with a toggle for the OD. It worked fine after adding a relay to the solenoid. | | |
#88374 08/30/2003 7:01 PM | Joined: Dec 2001 Posts: 17 Junior Member | | Junior Member Joined: Dec 2001 Posts: 17 | I am going with this same set-up on my 50 chevy truck. I have been told that you can actually hook 12 volts directly up to the solenoid with out hurting it. Is this true. If not, how many volts to use is the question? Thanks
Joe
#88375 09/10/2003 7:08 PM | Joined: Jul 2001 Posts: 12 Member | | Member Joined: Jul 2001 Posts: 12 | Thanks to all who replied to my original question about hooking up my overdrive! I plan to install the three speed overdrive within the next two or three weeks and will hook up a light to remind me when I am in overdrive so as not to lug the transmission. Update later. | | |
