Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (Rusty Heaps, panic), 51 guests, and 3 robots.
Topics128,009
Posts1,055,293
Members48,419
#883570 09/18/2012 9:34 PM
I have a 235 and I want to run my heater hose to the cab. I thought that the lower hose fitting at the pump would be sending the water to the heater and back to the top hose fitting. In doing so it seems to be backwards. Does the water push out the top fitting and back into the bottom hose which is at the pump. I want to have my shut off before the heater and I have it on the bottom hose connection which seems to be on the return. Thanks
first48 #883573 09/18/2012 9:54 PM
tclederman #883605 09/19/2012 7:15 AM
The heater supply is the top connection on the thermostat housing, with the return at the pump. The shutoff will work on either side.
If you block flow out of the heater core, no new water is going to enter it.
regards,
Leon
Leon #883656 09/19/2012 1:41 PM
Thanks Leon that is what I thought and I think I would like the shut off to be off the top connection so IF the heater started to leak in the truck you could shut it off. If I would stop it at the pump on return (which is what I have now) then water would continue to flow to the heater. Thank you for the information.
