1 members (Shade Baby),
21
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2011 Posts: 74 | I have a 235 and I want to run my heater hose to the cab. I thought that the lower hose fitting at the pump would be sending the water to the heater and back to the top hose fitting. In doing so it seems to be backwards. Does the water push out the top fitting and back into the bottom hose which is at the pump. I want to have my shut off before the heater and I have it on the bottom hose connection which seems to be on the return. Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | The heater supply is the top connection on the thermostat housing, with the return at the pump. The shutoff will work on either side. If you block flow out of the heater core, no new water is going to enter it.
regards, Leon | | | | | Joined: Jul 2011 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2011 Posts: 74 | Thanks Leon that is what I thought and I think I would like the shut off to be off the top connection so IF the heater started to leak in the truck you could shut it off. If I would stop it at the pump on return (which is what I have now) then water would continue to flow to the heater. Thank you for the information. | | |
