5 members (Rusty Heaps, Hambone, 3B, Gray_Ghost, Joe H), 223 guests, and 3 robots.
Topics128,151
Posts1,057,009
Members48,460
I'm installing a bed on my 1941 3/4 ton, and I'm not sure where all the cross sills are supposed to be located. The 1st and 2nd sills counting from the front are pretty obvious because of the mounting holes in the frame. The 3rd and 4th sills are not as obvious. Could someone please give me either the measurement of these sills from the front panel, or since the sills match up with holes in the bed strips, give me the number of holes back from the front panel. I've looked on the Mar-K website and searched this forum with no luck. Thanks!
My toys:
'41 Chevy Model AL 3/4 Ton
'40 Chevy Model KD 3/4 Ton
Hinomoto 209N Tractor/Backhoe
Norwood LM2000 Sawmill
PJ 16' Trailer
and a Brand New Shop!
Be what you is, not what you ain't, 'cause when you is what you ain't, then you ain't what you is.
I will be able to measure on my 3/4 ton this weekend, if someone else hasn't given you an answer by then.
My 46 GMC on Photobucket
Thanks 46. I think I've got it figured out. Appreciate the help though.
My toys:
PJ 16' Trailer
No problem, just PM me if you end up needing any measurements. I will be turning it into a shortbox within the next month or so though.
Does anyone else have the measurments for the cross sill locations? I need them for my 1941 3/4 ton pickup. I pm'd 46gmcpu and summerfi with no luck. Thanks.
Dan
