7 members (farmallb, Samantha, Opelika Tom, Oswald, Hanks custodian, 2 invisible), 79 guests, and 2 robots.
Topics128,089
Posts1,055,988
Members48,430
#882155 09/12/2012 12:48 PM
Im sure this has asked many times. How do i wire my fuel gauge? I got a yellow wire from the sending unit that runs to the fuel gauge. Does it connect to the E side or F side of the gauge? Im getting 12v from the E and 6 volts from the F terminal of the gauge. I also have a voltage reducer where do i hook it up? Thanks
Ex Hall Monitor
Ex Hall Monitor
Similar questions have indeed been asked a lot in the past. Use of the search function can help a lot. It leaves a lot to be desired but it does help. Also perusing the topics from the last few days can provide some info as well.
From two days ago.
Another good source is the Old Online Chevy Manuals site which has this wiring diagram.
I'm assuming you're looking for a '53 since that's part of your handle and you didn't specify in your post.
Tiny #883354 09/17/2012 8:34 PM
Is there a better voltage reducer to buy than others? I hooked mine up after about 20 minutes the gauge went up in puff of smoke! Will the reducer fail before the gauge and possibly the gauge will be saved when a reducer fails?
How/where did you connect the resistor?
What brand resistor did you use (vendor name and part number)?
I have used his one.
I connected to the back of the gauge...E terminal from the ignition. I'll need to check the brand
I also grounded the reducer...quality shouldn't be a problem...it shows as "runtz" with instructions from Fifth Avenue Antique Auto and I've had very good experience with them.
might be best to contact 5th Ave and discuss it, note he's a moderator of this forum, although he might not check in often
Flxible #883404 09/17/2012 11:14 PM
