| | | Forums66 Topics128,050 Posts1,055,646 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 36 New Guy | | New Guy Joined: Jul 2012 Posts: 36 | Okay, so this morning, I go to start the truck, and I got nothing. Tester says the battery is fully charged. This is on the 66 C10 by the way.
At any rate, turn the key and there is nothing. Gauge shows a draw on the battery when you turn the key, and all other electrical works - just nothing - not a sound when turning the key.
So, a bunch of my buddies were telling me check this, check that - whatever. We tried pushing it down the hill to pop the clutch and start it. All that did was lock up the wheels (like I slammed on the brakes). I think that was my fault because like an idiot, I had it in granny when I popped the clutch at about 15 mph.
Any ideas where to start this quest? Would I have had better results if I were in a higher gear?
Had the truck out on the road two weeks ago with no issues. This was totally unexpected. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, you need to be in 2nd, or if it's well-tuned and previously started easily, even 3rd should do it .... but you need to start with the starter solenoid as that's probably what's gone out - and this'd be better in the electrical forum
bill | | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 | I have a '65 C20. I moved it around the driveway for my niece to take some pictures and it started fine. The very next day I wanted to drive it to work and...nothing! I tested the battery and it was OK. It turned out to be the starter. I used to think that the starter gave you some warning before it died but I was wrong. Good luck!
1965 Chevy C20 Stepside
