0 members (),
52
0
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2002 Posts: 19 New Guy | | New Guy Joined: May 2002 Posts: 19 | I completely destroyed a fuel line fitting that connects the fuel line to the fuel pump outlet. It's a 1950 216. Where is the best place to get a replacement? Does the average auto store keep this sort of this in stock? Thanks. | | |
#8828 06/11/2002 11:24 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Yup, it's stocked in most auto parts stores, it's the same as steel brake line.
#8829 06/12/2002 10:15 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Yes, as 4ON says, it is available at most all autoparts stores. . Use a piece of string to measure your fuel line or tale yours off and take in to match up at the parts store.
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | 5/16 steel tubing. I would measure, buy one a little long and get a compression fitting for the fuel pump end. Get a spring tube bender and start bending at the carb end. After you work your way to the fuel pump, cut the line to length. You can also start at the fuel pump, working to the carb. Another option, if your existing line is in good shape is to get a compression fitting and cut off your existing line inside the flare (that's why there's a groove in the wheel on a tubing cutter). Personally, I wouldn't buy the stainless steel tubing, it's harder to work with than standard steel.
Fred 52 3600 69 C-10
| | | | | Joined: Feb 2002 Posts: 15 Member | | Member Joined: Feb 2002 Posts: 15 | If you don't want to make your own, try Inline Tube. The line from the pump to the carb goes for about 20 bucks. They are on the web and in many automotive mags. | | |
