1 members (Truckrolet),
154
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 130 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 130 | I have a 292 1989 crate motor that was for a large box truck. I put my 72 292 dipstick in and it reads at the very tip, under add a quart. I do have 6 quarts in it now. That is what the Chilton book said for it. Also my intake man. slants to the front like the engine should slant back more. Could I have a 7 quart motor? I'm not sure, but the box truck might have been a Vulcon, it looked like a 1T with dual wheels. Anyone Help? | | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | My 1970 292 holds 6 qts with filter. | | | | | Joined: Sep 2008 Posts: 130 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 130 | Thats what my old motor held. Since this motor was for a larger truck, it might have a deeper pan. It would work harder in a large truck. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Steve, I would just check the intake manifold with a level at the carb plate. It should be level.
Drew
| | | | | Joined: Sep 2008 Posts: 130 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 130 | Drew does yours slant forward? I did put a level on it, it does slant forward slightly,(the carb plate) about a 1/16th out of level. I set that engine up without the manifold on, OOOOPS. Never thought about it. It's funny, all those years I had that motor and now I just start to notice this stuff. I sent you a PM, my pan is the same. I'll drain the oil and make sure it's 6 quarts. I haven't started the motor yet so there won't be any in the filter. That way I won,t have another OOOOPS. Thanks Drew | | | | | Joined: Sep 2008 Posts: 130 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 130 | Drew I'm leaving for the week, so I wanted to let you know and all, that I did have 6 Quarts in my motor. Drew the stick I am using is the same that was on your engine, so I was using 7 quarts in that motor. I haven't changed the oil since 1989 but it sat all that time till about a year till you came and got it. Had to be the wrong stick. I never realized or gave it a thought. Last couple of years I drove it, I took it to Jiffy Lube. I was lazy and very buisy then and drove it daily for work. It never leaked, so maybe check the seals just to be sure. I put alot of miles on it and when I bought it it had alot back in 84. So there's the answer to 6 or7 quts. | | |
