| | | Forums66 Topics128,189 Posts1,057,337 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#88296 03/14/2005 9:42 PM | Joined: Nov 2000 Posts: 44 Junior Member | | Junior Member Joined: Nov 2000 Posts: 44 | My speedometer never worked very accurately, it jumps up and down from 20-30-40mph while driving. Recently while working on the dash (cutting a hole for cd player) the needle in my gauge fell out and is now sitting at the bottom of the gauge behind the glass.
My question for you guys is this, would you simply take out the gauge and put the needle back in place and proceed with a jumpy needle. Or would you replace the gauge completely to fix the jumpy needle OR is it a problem with the cable to the gauge that might be causing the problem?
any suggestion on how to fix this.... | | |
#88297 03/14/2005 10:30 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | It's possible to rebuild the speedometer. There are several places that will do it. Sometimes a little lube is all it needs to work right. You can buy new needles, they are a slip fit. A lot of times the jumpy speedometer is actually caused by the drive cable.
