| | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 143 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 143 | Go a 50 3100, all stock. Early this year the speedo started making a loud sound and subsequently stopped working. Got the cable off and found the cable broken off at the spot where the cable enters the trany. Speedo was shot, so I sent it off to be rebuilt. I ordered a replacement speedo cable from Classic Chevy in KC. Installed both this weekend and still can't get the speedo to work.
It appears that when the cables are tightened, the end that fits into the back of the speedo slips out and becomes disengaged, leaving the cable spinning. The new cable has some sort of red lock spacer on the speedo end leaving about 3/8" of end engaging into the speedo. The cable end also appears tapered. The cable doesn't seem to fit into the speedo correctly. When the cable spins, the inner cable slides further into the tranny end as there is no lock to limit the cable engagement into the transmission. So basically the cable keeps slipping out. Classic says this is the correct cable. I know this is a poor description.
Anyone purchase one of these cables from Classic? Any ideas on this issue? Thanks.
It never costs more to ask and it never costs more to think big.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if you still have that original broken cable, you should be able to see the difference in the ends and the length of the inner piece - yours may have been changed at some point in the last 50 years .... also you should be able to find a "universal" match for the original at a FLAPS
Bill | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | I think your problem may be the placement of the lock collar on the speedo end. The one I got from the Filling Station is 7/8" from the cable end. I would try to slide the collar further down the cable to allow it to fully engage the speedo drive. Note that on 2 spare speedos I have the depth of the hole is 7/8" so the 3/8" setback on your cable is not sufficient.
Ed
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Anyone purchase one of these cables from Classic? Any ideas on this issue? Thanks. I purchased one from classic a few years ago, but had a diffrent problem. The collar was swedged to far back ...pic... so when It was inserted it would bind ..insert.. I pick one up from carquest ..part number... ...3/4 set back... ...pic... ...pic... and its been working fine. Good Luck | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | I agree with Gus - get another cable. I replaced the old speedo cable in my '54 with 4-spd tranny with a 70" metal case cable from American Classic Truck Parts. It fits and works fine. I believe that the original metal cable from the factory was 68" or 69". > 70" metal case speedo cable - American Classic Truck Parts part #SPC-2 > Dual clip for mounting speedo cable and wiring harness onto firewall - American Classic Truck Parts part # FA-113 The old vinyl covered speedo cable had a plastic tip that inserted into the speedo head. I had removed and reinserted it a few times. When I finally removed it to lube the speedo, the plastic was twisted like a screw. Also, the old cable was barely long enough.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I find that the metal case cable is a lot easier to work with & fits better then the plastic ones. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
