0 members (), 89 guests, and 2 robots.
Topics128,105
Posts1,056,541
Members48,448
Ive got 52 3100 with a 235 from a 1960 chevy.. Daily driver, The clutch is worn out and the trans is tired. Im entertaining the idea of putting in a automatic trans,this would allow me to drive my truck all the time as my knees are wornout also. I have the transmission and I have a 6 lug rear diff to swap. ( not sure of ratio yet) Several questions. 1) good idea?
2) what gear ratio should i be looking for inthe rear end?Would really like to keep up with traffic on the highway,65 is plenty.
3) where can i get the adapter? Or are there other options?
Thanks, Oldblue48
I am not sure exactly what rear end you have but its probably an eaton HO 33 which has a gear ratio of 3.90:1 I have a 56 1/2 or 3100 with a 235 an what I am planning on doing is rebuilding the 235 motor keeping the original 4 spd which is a SM 420 transmission. I also have 3.90:1 eaton HO33 rear end. I know of a company in Casa Grande, AZ called Patrick's that have a kit that will fit into your rear end with 3.38:1 gears which will get you speeds on freeway of 70MPH. Thats what I will do to mine. Ifyou are looking to put a auto transmission OD will help you. There is another company called Advanced Adapters Inc. that was going to supply me with an adapter if i ever decided to put a v-8 in mine Hope that helps. call Patricks they can help he help me decide on what to do.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen
56 Chevy 3100
www.stoveboltengineco.com sells the trans adapter.
Drew
Tom (Stovebolt Engineering Co.) has said he was going to stop producing and selling the adapter mating an automatic to a 235-261.
He currently has some in stock.
Drew
Sent you a PM.
