| | | Forums66 Topics128,093 Posts1,056,478 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 46 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 46 | Ive got 52 3100 with a 235 from a 1960 chevy.. Daily driver, The clutch is worn out and the trans is tired. Im entertaining the idea of putting in a automatic trans,this would allow me to drive my truck all the time as my knees are wornout also. I have the transmission and I have a 6 lug rear diff to swap. ( not sure of ratio yet) Several questions. 1) good idea? 2) what gear ratio should i be looking for inthe rear end?Would really like to keep up with traffic on the highway,65 is plenty. 3) where can i get the adapter? Or are there other options? Thanks, Oldblue48 | | | | | Joined: Aug 2012 Posts: 566 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 566 | I am not sure exactly what rear end you have but its probably an eaton HO 33 which has a gear ratio of 3.90:1 I have a 56 1/2 or 3100 with a 235 an what I am planning on doing is rebuilding the 235 motor keeping the original 4 spd which is a SM 420 transmission. I also have 3.90:1 eaton HO33 rear end. I know of a company in Casa Grande, AZ called Patrick's that have a kit that will fit into your rear end with 3.38:1 gears which will get you speeds on freeway of 70MPH. Thats what I will do to mine. Ifyou are looking to put a auto transmission OD will help you. There is another company called Advanced Adapters Inc. that was going to supply me with an adapter if i ever decided to put a v-8 in mine Hope that helps. call Patricks they can help he help me decide on what to do.
"As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear God protect my sweet ride." -Amen 56 Chevy 3100 | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | www.stoveboltengineco.com sells the trans adapter.
Drew
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Tom (Stovebolt Engineering Co.) has said he was going to stop producing and selling the adapter mating an automatic to a 235-261.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Tom (Stovebolt Engineering Co.) has said he was going to stop producing and selling the adapter mating an automatic to a 235-261. He currently has some in stock.
Drew
| | | | | Joined: Nov 2001 Posts: 1,519 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,519 | | | |
