8 members (Goach2, JoeDude, asilverblazer, Wally / Montana, Wayne67vert, klhansen, 2 invisible),
101
Mod | | | Forums66 Topics128,197 Posts1,057,263 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 112 | So where might I find replacement parts for the rubber and metal bushings between the shifter linkage rods and the tranny shift levers? I've checked LMC, asked of American Classics, and had a NAPA owner search for me...and nada! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yer looking for something that isn't available, they were originally some rubberized plastic .... look for something that'll do the same job - check the Help! rack, #38374 bronze door hinge bushings, ream as necessary, last forever with an occasional dab of oil when you lube the truck
Bill | | | | | Joined: Oct 2011 Posts: 112 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 112 | | | | | | Joined: Feb 2004 Posts: 29,878 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,878 | I've fabricated those bushings with a piece of oilite bronze and a lathe- - -just a couple of diameter cuts, a drill bit the right size, and a cutoff tool. It takes about 10 miutes per bushing once you get the dimensions right. Jerry
