| | | Forums66 Topics128,114 Posts1,056,282 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 132 'Bolter | | 'Bolter Joined: May 2009 Posts: 132 | The '39 gauge has two rear terminals. One is larger than the other. Which takes the power, and which takes the wire to the sender unit?? The back of the gauge does not appear to be marked in any way.
Thanks | | | | | Joined: May 2009 Posts: 132 'Bolter | | 'Bolter Joined: May 2009 Posts: 132 | The mystery is solved.
Jim Carter Truck Parts (they rebuilt the gauge) just responded with the answer that "The sending unit wire goes on the full side of the gauge."
