3 members (ShopRag, 55shaker, Otto Skorzeny), 106 guests, and 0 robots.
Topics128,163
Posts1,056,920
Members48,458
#880950 09/07/2012 9:24 PM
does anybody know where i can get a set of king pins and bushings for my 36 1.5 ton?
http://s1055.photobucket.com/user/baldybenny/library/
1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
Wait for someone to confirm or correct this information.
http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc0528.htm
It looks like your 1936 1.5 ton might use the same set as a 1952 3/4 and 1 ton.
Rockauto.com has the 1952 set and gives dimensions.
thank you so much tim! i'll check it out.
i took my truck apart and you are right,rockauto has the king pins i needed and they also had oversize so i can fix the axle,great call with rockauto! thank you so much, the king pins set is the same as 1952 3/4-1 ton trucks.
