| | | Forums66 Topics128,162 Posts1,056,936 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 3 New Guy | | New Guy Joined: Jul 2011 Posts: 3 | anyone know of a later model 6 lug rearend that fit in my truck .putting 350-700r4 combo in it want to keep the 6 lug so i can still run my 15"artilrey wheels.looking for one around the same size from backing plate to backing plate? | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 |
Evan
| | | | | Joined: Dec 2011 Posts: 55 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 55 | Not to hijack the thread but would a rearend out of a 1958 half ton work on a 51 half ton? | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Not to hijack the thread but would a rearend out of a 1958 half ton work on a 51 half ton? Yes and it will come with 3:90 gears a little low for an automatic, albeit a little wider and you will have to install some spring perches in order for it to fit. | | |
