0 members (),
75
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 16 New Guy | | New Guy Joined: Jan 2009 Posts: 16 | Need help in determining how to repair a break in my rear window trim on my 42 short bed. I tried JB weld and let it cure for 2 days and 20 seconds after picking it up it cracked right back. I have read about some welding techniques but I figured old school know how was the first choice. Any bolters had this issue and fixed it? Thanks for the help. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Got a photo we can look at for ideas?
| | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | Not on that particular area, but I have used the flea market repair rods for aluminum/pot metal to repair the pot metal fender extensions on a Fairlane. It had some cracks in it, and they have not re-appeared in the three years since completion (kow) You do have to watch the heat, it is a very fine line between melting enough to add the filler rod and a dime sized hole just dropped out. The finer your torch size the better... | | | | | Joined: Jul 2011 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2011 Posts: 55 | I second Roberts suggestion those rods work really well for this application and are normally quite strong. I use a propane torch to keep the heat down. Prep is key for using these things.
Eric
| | | | | Joined: Jan 2009 Posts: 16 New Guy | | New Guy Joined: Jan 2009 Posts: 16 | | | |
