1 members (Peggy M),
39
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 103 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 103 | I have the seat bottoms and seat back that came uninstalled with my truck (not upholstered). I'm assuming they're the correct frames for the truck.
Since they weren't installed on the truck, I'm not sure how the seat frames are mounted. The seat back has a couple of brackets at the top that appear to attach up under the bottom of the headliner (haven't removed the headliner yet).
The bottom frames seem to just rest on the riser around the tank, but I haven't got them to where they seem to fit just right.
Anyone have any hints or pics on how these frames attach?
Thanks.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I have a few pics of my '38 coupe but I don't know how similar it is to the truck.
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | All three seats fit just as you describe. The seat back rests has two tounges that slip into a brace just under the rear window and and the seat rests on a saw tooth brace at the bottom of the cab behind the seat cushion allowing you to set the seat in three different positions. The seat bottoms do rest on the upright around the cas tank and more or less slip into place.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Man, nothing like the car. Good thing I didn't jump in with pictures and muddy the water.
| | | | | Joined: Aug 2012 Posts: 103 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 103 | Thanks guys. I hope to start working on the seat frame soon, cleaning off the rust, reconnecting the springs where needed, painting, and reupholstering. | | | | | Joined: Aug 2012 Posts: 103 'Bolter | | 'Bolter Joined: Aug 2012 Posts: 103 | Meant to ask... are there an bumpers needed anywhere? I see them sold on some of the parts websites, not sure where they need to be installed.
Thanks | | |
